Re: turning my 70;s 115 jonhson into a 140
If you have a 4.38" bore 115, it's 1969-70. You've already got the same size carbs as the 140. The 1969-70 115s came with 1-5/16 inch carbs, and I think most of the 135/140s also came with 1-5/16 (some had 1=3/8).<br /><br />Your motor's different from the 1973-77 V4s, and not much interchanges with them. The 1969-70 115 was the hottest motor OMC made at that time, and frankly I think it's got just about the right powerband. They goosed it a bit more with the 1971-72 125s - still flatbacks and an insignificant bit more displacement. If the motor's not doing what you need on the boat, make sure it's running right (check compression, etc.), propped correctly, and as high on the transom as it'll go. You can see the old posts for further discussion.<br /><br />You can get more from it by milling the heads, squaring/raising the ports, relieving the exhaust, etc. but every bit of it moves you closer to melting a piston top.
