Twin 150 Fichts won't rev past 2500
jerryjerry05
Twin 150 Evinrude Ficht.
Starboard starts and idles fair.
Good compression.
The port doesn't want to idle well at all unless the balls squeezed.
The check engine light comes on both motors and won't rev past 2500 rpm.
New hoses/squeeze balls and cleaned oil tanks new squeezies.
What would cause the "check engine light" to come on??
Thanks
Did you re-prime oiling system when tanks were cleaned ?------And no , you can not run 50:1 premix in these motors.
jerryjerry05
Yes we primed the oil system.
New hoses, new squeezies and primed the system.
Thanks.
jerryjerry05
Gonna check pressures in the AM
But both motors throwing a check engine light?
Gonna try to get codes then too.
Thanks for the suggestions.
jerryjerry05
What should the pressure on the pump be?
Gonna get the factory manual, they(EBAY) have some for 1996/97
will they work for a 2000 150
Or where can I get the right one?
Thanks
