twin 1992 evinrude 70hp how to connect temp gauges
nitro277
On what cables should I connect the temp gauges too I have a 1989 CC robalo with the twin 70's and I would like to have the gauges connected...could anyone help me out I'll appreciated greatly thank you!!!!!!!!
emdsapmgr
Re: twin 1992 evinrude 70hp how to connect temp gauges
You'll have to add a sender to the engine to drive the gauge. This engine is factory setup with a tapped, threaded hole in the head for a sender. The sender you need is very short, perhaps 3/4 inch long and bottoms out inside the head. You will need to check the compatibility of the sender with the gauge to make sure it reads properly. Connect the gauge to a power source, the single wire to the temp sender is the signal.
nitro277
most thankfull I'll get right on it the engine already has the senders just like you said I'm going to work on it
