kylejb2663
- Aug 13, 2011
- 177
Hey Guys,
So I would like to winterize my boat this year myself and take the time to learn the process and do it CORRECTLY!
I have a 28' Chris Craft AmeroSport 284 with a pressurized water system, hot water tank is disconnected (Previous owner did that, eventually I'll put a new one in), and of course two holding tanks, one fresh water, other for black water. Engines are twin 305s with fresh water cooling and of course OMC Cobra Outdrives that have been serviced yearly.
What is needed for me to perform the winterization in my driveway? tools and product wise/oil type, lube type for outdrives, etc.
Also, I know with the Cobra's you want to use the top hole for filling and bottom hole for draining correct? so that an air bubble is not created?
Also, does anyone know how to access the Shower Sump System? Turns out I think I may have some water backing up into the drain in the shower which means I probably want that fixed before winter....!
Thanks guys!!
Kyle
Thanks guys!!
Kyle
