Hello all,
I wasnt sure where to put this post since it deals with a few different areas of the boat but my initial feeling is the engines so I am starting here. I apologize if it needs to be moved. I searched and I found numerous posts on lists but I didnt catch any with a multi-hull and twin OBs.
Anyway, I have a 22 CC Prokat with twin DF140s. The issue I am having is that when at speed, it lists to the port side quite a bit. I can counteract this (as you do with a cat) by working the tilt/trim independently. The problem is that the tilt of the stbd engine to counteract this is pretty extreme (not to cavitation extreme, but close).
The port engine is a 2002 and the stbd is 2007... dont ask
The specs show the two motor weights to be the same so i dont think that is the issue. I did notice that the vertical trim tab on the lower unit of the port engine is deflected much more than the new engine. I dont have any issues with prop torque regarding steering but am wondering if that could be the culprit?
I have also seen posts regarding the height of the engine affecting some v-bottom boats so I plan on measuring that precisely when I get back to the boat this weekend. (cavitation plate in relation to transom bottom)
Due to hurricane Hanna it is out of the water right now so this is a great time to investigate this.
Other facts:
- Boat sits level when at the dock
- Boat does not have horizontal trim tabs
- For the life of me I cannot remember if it was as bad before the new engine was put on
- New engine has prop from previous blown engine so it is the same as the other
- Looking with the naked eye, engine heights look the same (again, i will measure precisely this weekend)
Anyone have any good place to start to troubleshoot this or anything else that might cause this? Wanted to head to the boat this weekend armed with things to try
Thanks in advance,
Charles
Other facts:
Thanks in advance,
Charles
