Re: twin engines for 20ft alaskan /lund
No -- MPG is definitely NOT the best measure of fuel economy for a boat, especially when comparing two or models, types, etc. How far you go on a gallon of fuel (MPG) is only relevent if you add the time factor and it is also relevent only for the boat being tested. You can test another totally different boat and get, for example, 10% less MPG. But the other boat may be 15% faster. So in the end, over a given distance, the boat with lesser MPG will get to its destination faster and hence burn the same or even less fuel. The key is flow rate over time, not volume over distance because speed is not included. Airlines use a similar method but they use pounds of fuel/hour which can be calculated into gallons/hour as well.
