Re: twin prop help/puzzle
dont know the gear ratio. is there a way to look it up via serial number ?
what would be the best way to test the tach ? some thing from the autoparts store ?
do you think changing the dia. of the props from 15 to 16 make any difference ?
Are there any horsepower decals? Yes, S/Ns will help if they are still stock . . . We only really need the gear ratio for reality checks.
First thing is to look behind the tachs for a little switch to set them for different number of cylinders, usually 4, 6 or 8. The tool you need is sometimes called a phototach or a shop tach, see what they have available for rent or loan, I've never checked. There are fairly cheap ones available these days where you put a piece of reflective tape on the crank pulley and then aim at it with a "gun" that records the RPM.
Do not change the props or even consider size changes until the tachs are right. Good data first, then make decisions. Things may be just right as is. Don't worry about diameter even then, pitch is the number to concentrate on and if RPM is low, we go down, not up . . . Right now we don't know.
