two batteries in a cabin cruiser how to wire
2stroke1971
I bought an old Bayliner Capri, a 19 foot cabin with the Volvo powertrain.
It had no batteries in it, and Ive got a couple for it. One is a big one, and one smaller. This is the first boat Ive had that even needed a battery, except that I used one to run my fish finder and nav lights on my old skiff.
So obviously if all works the way it should, the battery charges as the boat is running. But then after a stop....I suppose it drains a bit, especially if you are running a bunch of crap like radios, videos, whatever. I think with the kids on it, I may be running a few accessories while anchored out there somewhere.
So...you obviously want enought juice in the big battery to start the motor, but I imagine you also want the second battery to charge while running.
How do you hook the two together first, so that the second battery also charges. And is there any type of switch I should rig so that when anchored for a period of time Im only using the second battery? What do some of you guys do?
Silvertip
Re: two batteries in a cabin cruiser how to wire
Use the "Search" feature. This topic is discussed to death and the answer is generally the same. Install a dual battery switch or a VSR (voltage sensing relay).
Seon
...How do you hook the two together first, so that the second battery also charges. And is there any type of switch I should rig so that when anchored for a period of time Im only using the second battery? What do some of you guys do?
