two cables???
bretmoua
On my 1996 Mercury XR6 150hp motor, which one is the shifter and which one is the throttle cable? Any pics?
M
Maxz695
Guest
Re: two cables???
On a single shifter, shift fowards and the one that moves first is the shifter cable. The throttle cable then moves after the gears are shifted to increase the throttle. If it,s not hooked up to the shifter and engine then I believe both cables are the same length and can be used for either.
