Two issues:
a) first, the steering seems increasingly stiff. Hard to turn wheel while docked in my garage. Does the steering wheel and cable at the wheel take any lubricant? It actually seems that the stiffness could be from up front at the wheel and not back at the motor. Back there I've greased the tubes, but I'm all ears in case I'm not doing it correctly. Those zercs are impossible to get at, however, so I drew out the rods at the motor and greased them directly.
b) second, that bolt fitting that attaches the steering arm to the motor arm sure seems flimsy. I am picturing it coming loose and then losing control of the boat. The lower nut must be reversed thread because a clockwise turn loosens it. Here's a picture. Is something wrong here?
