Two stroke oil question
Skeetor
I cant find any Yamaha two stroke oil anywhere near me and my question is, what other brand can I use?
Thanks in advance
T_Herrod
Re: Two stroke oil question
I use Valvoline. I'm sure others will be able to give you more facts but as long as it is TCW3 approved you should be good to go. Which engine do you have?
N1NE1
I personally use Yamaha 2m only (I have200 HPDI),A cheap friend uses any tcw3 (he has a 225 ox66). The difference, he is mosquito/green head control with excessive smoke.Cheaper oil makes for rough running, carbon build up and stuck rings.I get zero smoke.You should buy the oil in bulk and just have it delivered.If you don't care about your motor and want potential issues,go with the cheap stuff
Skeetor
Thanks guys. I have a Yamaha V150TLR.
Rudy
