Re: Type II CD Ignition 1979 15 hp 'rude
Xcusme,<br />Please pardon my lateness in replying to your response, I really do appreciate the help offered by you or anyone else in this forum. the answeres to your questions are as follows:<br /><br />Did you replace both upper and lower crank shaft seals with the rebuild?? <br />Yes<br /><br />Could you have a leaking fuel pump diaphram sucking extra fuel into the top cylinder??<br />Thanks for that one, I never thought it was possible. I'll have to check it out.<br /><br />The carb is common to both cylinders but the reeds are not. Did you do the dollar bill test to look for 'back puffing' of the carb?? <br />Again, please pardon my ignorance, but could you explain the dollar bill test?<br /><br />Do both plugs look the same??<br />Yes<br /><br />I don't think I mentioned it before, but I also replaced the reed plate, but used the old reeds and backers. However they looked fine under a 20x lupe and met the specs of .010" gap -<br />centered according to the book.
