Type of antifreeze
dtskidoo
is plumbers antifreeze good enough to pour in hoses thermostate etc. to winterize . Thanks for any replies
180shabah
Re: Type of antifreeze
Not sure what plumbers AF is - unless you are talking about and alcohol mixture.
I use a gasous(sp?) mixture a high nitrogen/oxygen content. If it freezes, it means Al Gore was right, and I have bigger problems thatn a cracked block.
wajajaja02
I learned that if you mix orange and green, you get jello that doesn't dissolve back out. so I am giving away my stock pile of orange, and will drain off any in my systems that have it.
180shabah
And they also need to be recovered BEFORE you hit the lake in the spring.
HT32BSX115
Most automotive anti-freeze mixtures are also anti-corrosive.
plummers anti-freeze may not be.
Regards,
Rick
I use a gaseous mixture a high nitrogen/oxygen content.
Ayuh,.... Me Too,... Nothing but the Best for my barge....
I also know how to use the Spell Checker,........:D
HT32BSX115
Yeah.....it's really has to be pretty cold for that stuff to freeze....:eek:
JustJason
You really want to use NONTOX RV antifreeze.... it's usually pink.
If you use the NONTOX then you can just hook the muffs up in the spring and let it flow down the drain without the fear of the EPA knocking at your door....
