Tyvek
maproy99
I was thinking, wouldn't putting Tyvek down on top of the wood below the carpet really help to extend the life of the floor and wooden supports? Since Tyvek is supposed to allow moisture to go 1 way but not the other, shouldn't it help cut down on the moisture that is down inside the deck? Any thoughts on this?
I'm not quite ready to do a floor replacement, but some of the plywood has become unglued............
tpenfield
Re: Tyvek
No . . . tyvek acts as a moisture barrier for things that have thermal differences. like houses, etc. It is really not going to perform any sort of positive function in isolating moisture from the floor . . . no more than proper fiberglassing.
I do not believe that the tyvek will act as a one-way valve for moisture. It is breathable at a microscopic level . . so moisture will follow gravity in this application.
Woodonglass
Re: Tyvek
This ^^ is correct. If the plys are delaminating then you will have to allow them to dry out and then attempt to re-glue them. this MIGHT work if the plywood is not TOO saturated. Otherwise you may need to cut out the damaged portion and replace it. Lots of help here on how to do either.
archbuilder
Re: Tyvek
interesting question, but I don't think it will work well. Tyvek actually takes advantage of the fact that water in a vapor state is much smaller than in its liquid sate. In its liquid state, surface tension causes the molecules to clump together, forming large "spheres". In its vapor state it doesn't clump. Water in a liquid state will not go through tyvek because of this. However, when the humidity level on one side is lower than the other, the water will migrate through the membrane in vapor form. (Look up water vapor pressure). That is why it won't allow liquid water into a wall, but will allow the liquid to migrate out of the wall.
In theory I think it would work on the deck, in practice you are going to have screw holes wear spots (from walking on it), etc that will create holes for the water to get though....a liquid aplied mebrane, I.E, fiberglass will work much better. Best of both worlds would be if someone created a breathable fiberglass.....which would keep water out, and allow any water that did get in to migrate out instead of being trapped.
maproy99
Re: Tyvek
So, any other great ideas on how to water proof the wooden deck? I assume you could just throw a few packs of 40 pound salt down in the bilge to keep the moisture % down and keep mold from starting.
archbuilder
Re: Tyvek
About the only way I have seen it done successfully is with fiberglass or epoxy....and eventually the water will find a way through. Best you can do is put down a good layer, then make it a habbit to let the deck dry out after use before you put a cover over the boat. And store it inside, most decks will last a really long time if you do that.
jigngrub
Re: Tyvek
Seal your decking with 3 or 4 coats of epoxy resin, I only seal the topside and edges leaving the bottom bare so the plywood can breathe.
Then a good water shedding deck finish like marine vinyl or some sort of coating like Tuff stuff or kiwi grip and the like. The idea is to get the water off of the deck and into the bilge where it can be drained by pulling the plug.
Keeping your boat covered or stored inside with the bilge plug out when not in use will keep the insides bone dry and your hard work restoration will outlive you.
MWBoatFan
Re: Tyvek
Anyone ever add a vent system to a boat? Say something along the lines of electric fans in the deck - something you could "snap a cover on" while underway but then when you park the boat you could fire up the fans to literally circulate the air around the deck and internals to make sure of no mold or rot occurring. Maybe even something you could plug in once you park it in the garage. Or even something on a battery with a timer system.
Just thinking out loud here.
:D
maproy99
Re: Tyvek
:D
Computer fans. They run on 12 volts and are designed to run a lot of air through. Also should last many, many years.
Well, marine grade plywood would also be a good place to start. When it comes time to redo my floor, it should never have to be redone again.
jigngrub
