U bolts torqued at ?
bonitoman
What should I torque the ubolts that support the wood on the trailer to support the Hull? 50 FT lbs. 75 lbs? Thanks
Re: U bolts torqued at ?
If they're 3/8" bolts,....... 30/35Ft.lbs is Plenty........
If they're 1/2",........ 40/45Ft.lbs will Do........
50Ft.lbs is More than Enough.........Much More,+ You'll Strip the Nuts or Bolts...............
Texasmark
Never thought about it. Pulled them down till they felt good and tight (not overtight, good and snug type of tight) and that's where I left them. Let's see, been boating since early '50's and never lost one yet. d:)
No brag, just fact!
Mark
