Re: U joint bellows adhesive?
I would suggest you do, and here is why.
While it's not NECESSARY to glue it in, it is a good idea. As you start to put the drive on the ujoints flex and can knock the seal out of place when you can't really see what is going on. When it's glued in, it doesn't move so easy. Some experienced tech use nothing, and some use grease. I use bellows adhesive because it's cheaper than to replace ujoints, gimbal bearing, yokes and seals for my customers, because I bumped it accedentally.
But Chris did answer your question correctly, you do NOT NEED to
