U-Joint removal in Alpha One
bobafett
I have my upper drive off of my 1986 alpha one. I am having trouble getting the u joints removed for replacement. I have taken off c clips but how can I get the u joint out of the spider? My book doesn't do a good job showing/explaining. Any suggestions?
Laddies
Banned
Re: U-Joint removal in Alpha One
Without a u-joint press, you can ussally tap on the yokes to remove the caps do not tap on the caps as they will flair and give you troubles
Trent
Best way is to use a press and press them out. You could use a socket and knock them out if thats the last resort.
mikeneal
A correct size socket and a large c clamp will also work. If I remeber correctly you need to notch the socket for the u-joint right next to the upper assembly.
DHPMARINE
Is there clearance for the bearing caps to come off the short yoke? I remove the complete u-joint shaft from the upper drive when I replace the u-joints.Good time to replace the yoke oil seal too.<br /><br />DHP
Originally posted by DHPMARINE:<br /> Is there clearance for the bearing caps to come off the short yoke? I remove the complete u-joint shaft from the upper drive when I replace the u-joints.Good time to replace the yoke oil seal too.<br /><br />DHP
No,.... There's a Clearence Issue with the Big Castle Nut,........<br />You'll have to Grind just 1 of the tabs down to get the room,......<br />Then you can drive 1 cap off,.. Rotate the shaft 180*s,+ drive the other side off.....<br />Do Worry,...... It's still usable with 1 of the tabs Trimmed......<br />Just Don't Remove anymore than absolutely Nessessary,............ ;)
Rhadley
C-clamp and socket(s) works great--I didn't have to grind anything when I did it.
