natemoore
Master Chief Petty Officer
- Jun 13, 2009
- 844
If anyone here is familiar with Harbor Freight's U.S. General cylinder leakage gauge set, I'm not understanding this thing.
First, the left gauge has the regulated air and the right gauge has a percentage leakage scale, 0-100%, with 100% being at about 8 o'clock and 0 % being at about 4 o'clock and 50% at 12 o'clock.
I put the no.1 cylinder at TDC on the compression stroke by turning the crankcase until the timing mark was at 0 and the ignition rotor was pointing at the no. 1 spark plug wire.
When I connected the gauge and cranked up the pressure to 70 or 80 psi, the right gauge went all the way past 0 % leakage all the way down to the 6 o'clock position. Since I could hear and feel the air coming out of the oil fill hole (and it was quite a breeze) I assumed that the gauge should read something in between 0% and 100%.
So, I bench tested the gauge by hooking it up to compressed air and putting a blow gun on the other end, assuming I could simulate a perfect engine and a worn engine by how much I depressed the blow gun's handle.
Got the same weird behavior.
The directions that came with the tool said to hook it up with the regulator closed, then slowly increase the air pressure until leakage dial read zero. "Now you can read the percent leakage." Doesn't make sense to me.
Help. Thanks.
Help. Thanks.
