MassillonBuckeye
- Jul 26, 2010
- 400
So just bought this motor as a fix-er-up. P/O stated it was only running on 1 cylinder and it was probably the power pack since the had already replaced the coil. He said he didn't want to throw any more money at it so sold it to me. After bringing it home, I tested for spark and hard spark both cylinders much to my joy! Another quick inspection turned up a slice into a fuel line.. No wonder it was running rough! Decided to rebuild the carb since I saw a bit of water on/in the water pump. Popped it off and noticed the nozzle was cracked? Not sure how, but I decided to see if I could pop it out and replace.. Well I opened the nozzle chamber plug and see this.
The tube was against the inside of the nozzle. So I tried to back the nozzle off a bit and ended up with this:
Can I fix this?
*emulsion tube. And it appears I am out of luck lol
If this thing isn't working, I'm looking at a new carb. Whats its purpose? What are symptoms of it malfunctioning? I have a venturi broke and sideways in a carb once. No top end. I'm guessing that's what I'm going to have here.
Can I fix this?
