Ujoint replacement Volvo 270
fireman24mn
i have a mid 70s glastron with a 302 and a 270 outdrive i need to replace the u joints. I was wondering if there is a part number for this my local volvo dealer said i had to buy the whole shaft. I am replacing the bellows had a water intrusion problem should fix that but one u joint was bad so i need a part number so i can replace both of them.
robjen1019
Re: Ujoint replacement Volvo 270
Shouldn't need whole shaft. I know on my 290 it used the same bearing as the mercruiser alpha drives. I got mine on ebay.
fireman24mn
i can get some off ebay but i would like to find the parts this weekend and put it back together
