Unable to shift into Reverse
kam80500
Took boat out this weekend. As we were unloading into water we had difficulty moving shift lever into reverse. I tightened the threads at the shift cable connection and that took the resistance away at the shifter but now it just grinds and smokes in reverse. Any idea what I should look at ?
95yj
Re: Unable to shift into Reverse
For anyone to be able to help you here, we need to know at bare minimum what boat you have, what engine and what outdrive.
Ayuh,......
And Where is it Smoking,..??..?.......
kam80500
its a 1986 50 hp outboard mercury outboard on a pontoon
That Explains it,........................
You're in the Wrong Forum,............
You need to post in the Mercruy Outboard forum,.......
This is the I/O forum......
