Hi all,
Having problems with the search part of the forum so please bare with me.
I have got the evinrude motor started that i had purchased with the boat 3 years ago, but it will start on the key without the lanyard in place and will not shut of with the key.
I have followed all of steps in the manual regarding the igintion barrel and replaced the original one with a replacement one, tested as per the steps in the manual and all ok.
I did replace the original kill switch as this was constant open circuit (button depressed/open) so i think that problem has been eliminated also.
The motor and controls were original with boat and all fitted the engine is a remote start with the prewired remotes.
Sorrry forgot to add from the original oem manual i appear to have a 30hp "R" model with ac, no model number on the transom bracket so cant help with that one and after speaking to the "Rude" dealer the powerhead core plug numbers dont tally with anything he has come accross.
Not had chance to change or test the starter solinoid could this be at fault???.
Regards
UK member
Regards
UK member
