I made this tin can heater out of a coffee can.. I put a porcelain lamp socket in the bottom of the can, then I put a foot on the can to keep it from rolling...150 watt light bulb. I have plenty of room under my motor to accommodate the can.
The hull is aluminum.. If you have a fiberglass hull, I think you could place a piece of fiberglass insulation under the heater.. What do you think... will it work?
