I have a new yahama 150 hpdi 2 stroke engine on a 1988 18.6 boston whaler outrage. I can not get the engine to hold rpm between 2000 and 2900. top end is 5800 rpm and otherwise the engine runs fine. with the 17 pitch prop i kinow i am a little under proped but is it normal that under propping won't allow the engine to hold a certain rpm. The boat jumps out of the hole and settles at 3100 or so . if you pull back on the throdle to say 2800 it holds for a minute AND then slowly drops the rpm to 2000. this makes it impossible to run rough water off a plane. The mechanic says i need a 21 pitch prop , it just doesn't make sence to me. help!!!
