understanding paint/gelcoat
neilmcg
Hello,
I have an '87 Supra with a single-color gelcoated hull and deck (there are some accent colors on the deck, but I'm not concerned about that.) I want to change the entire color of the boat (excluding those deck accent colors.) I've heard that marine paint is easier to work with and can still result in a glassy high-gloss finish. The question I have is twofold:
1. Can I use the same paint for the entire boat (above and below the waterline) if it's in freshwater? (It's in the water all summer)
2. If not, is is feasible to have top and bottom coat paints match with equal color, gloss and durability?
As a novice I appreciate any help.
Thanks,
Neil
Re: understanding paint/gelcoat
Ayuh,.... Absolutely,....
I use a Martin Senour line of 2-pt urethanes called Prisim...
Above,+ below waterline, on trailer boats,+ dock boats as well...
Expensive, but shines like Glass..
neilmcg
Thanks for your response. Once I begin the project, I'll post pics.
neilmcg
I searched their website and found nothing regarding Prizim or 2 part poly. Did I miss something?
Ayuh,..... Did you look here,...
