According to my VP manual the normal operating trim range is +/- 6 degrees. Above that range the rpm's should be lowered otherwise there will be too much stress on the U joint. On some other place I found that the drive movement range from side to side is +/- 28 degrees...but not a word about allowed rpm range. For U-joint as such there's no differene wheter up or down. So what to make out of this? Is it allowed to "floor it" while turning?
