MobilePC
- Mar 6, 2008
- 11
Hello,
I've been in the process of saving a 28' 1971 Sportcraft Spotfisher for working on 5 years! (I really shouldn't count the year that I was on crutches)
It's been a lot of work, from rotten stringers, transom etc etc etc. Certainly I would have never been able to get this far without the wealth of knowledge found here!
I'm finally getting to the fun stuff - installing the engine and out drive. (this might not seem like fun, but compared to the months of cutting and grinding fiberglass I assure you it is!) The boat originally had Merc gear which I am converting to Swedish.
I bought a 7.4 GL with a 290 DP-B sight unseen and had it shipped up here which has been a bit challenging to install, having never seen the original setup. Most everything is different from my "little boat" with a AQ140a/280 setup that I've had 25 years.
As with every other step in this process, the more I learn the more I realize that I don’t know. I've found a couple of parts that came with the engine/drive that I have not been able to identify from any of the manuals, exploded diagrams and other goodies that I have found thru iBOATS. They are pictured below: There are 4 of the “pins” - 2 of which were broken in half at the threaded bolt holes. They are 5 inches long. There are 2 of the “plates” which are about 8 inches long.
Any help identifying these will be appreciated!
