Re: Unique Electrical Problem
I have absolutely no experience with a boat's ac power source/system. But maybe I can get the ball rolling.
I am going to make some assumptions and propose a course of action to locate a possible short.
Assumption 1: The boat by your description is on the "hard".
Assumption 2: There is a faulty circuit leaking current to the dc grounding system.
Assumption 3: That there is a circuit breaker panel that isolates each ac and dc circuit.
Assumption 4: That everything not permanently installed into the ac system is disconnected.
Assumption 5: That the ac circuit is not supposed to use the boat's grounding circuit as a return.
Action 1: Turn off all ac circuit breakers. Test for leakage to ground as performed before.
Result: If "0" then problem is in one of the circuits.
Result: If problem persists then source of problem is between the ac inlet and the breaker board.
Action 2: If "0" then energize each circuit breaker individually until problem reappears then visually inspect that circuit and test any equipment on the line. Could be the A/C, refrigerator, built in chargers, lights, plug in accessories or an outlet. Check for cross contamination between ac system and dc circuit.
Action 3: If problem persists, visually inspect and test wiring and inlet for a short to boat ground. Look for frayed wiring, burned contact at the inlet and anything else that is not supposed to be there.
As I said, I have no experience with the ac systems on a boat but this is how I would start looking for the problem. Then as I was testing I would be learning how the system was designed to work and would go from there.
Someone with the knowledge of the system will probably be able to chime and be of greater help.
