Universal control box
kbh121956
There are a couple of different controls on ebay. Also there are some main wiring harnesses. Do you need both? The Chrysler control will work but as Jerry said the wiring harness with Chrysler's, they use a separate 3 wire harness for the tilt. A person can always paint a used control to make it like new. Keep looking on ebay as these control boxes come and go daily.
Asnyder19
I do have the wiring harness so really all I need is the box. I would really like to have the key on the box if I could. Really appreciate all your help guys, thanks!
jerryjerry05
The Chrysler boxes will work.
And if your REAL LUCKY!!!!!?????
You might find a box with T@T in the handle????
They made a few, I saw ONE a long time ago.
kbh121956
You found one. Not a bad price either. Keep us posted and good luck.
Asnyder19
Little update guys, had to get a new trim switch but I got everything in and works great! Now I just need to figure out what model my motor is exactly so I can get an impeller repair kit The water coming out is looking a little weak.
