Unkown MFG?
reelfishin
I looked at an odd MFG today.
I thought I had seen or at least seen pics of all the various 1960's models but this one is new. It's no doubt an MFG, it looks like a Niagara on steroids.
The hull measures 23' 1" long, is 88" wide, has a short forward bow deck and a very low plastic windshield. The model year on the title, which appears to be the original title says 1960. It's bigger than the Seaway, but sort of resembles it. It's super light, has no flotation, no floor or deck and no provisions for one. The inner hull is just ribbed glass with a rib about 1/2" tall the whole way up to about the 1/4 way point on the sides. Nothing is painted and its all in white gelcoat. The dash area has no cutouts where it ever had a steering wheel, there is no foward hatch although there's the outline of where one could be cut into it. The transom is some sort of solid composite, which looks like hardened pink resin. Its got a pair of rigged together Merc 50 tiller motors and a diagonal bench at the port rear corner. No other seats and no other place where they could have been or could have been attached to. You walk right on the inner hull, and it's rock solid. The last owner has several rows of long planks just laying in across the floor so you don't trip on the ribs. It reminds me of an aluminum hull with no interior. The windshield is super low, only about 12" tall, it does nothing for the boat at all. The interior is huge, it's nearly all wide open. The bow deck is only about 4' back from the tip of the bow, the splashwell is only about 8" wide. There are no holes drilled in the transom, the two motors are clamped on, and connected together by to jumper cables which sync the motors. The operate from the left motors tiller handle. Its in the water and I'll have to drive it to the it's trailer, so I'll find out how such a beast works with that set up.
Any idea what model this cold be? The biggest thing I see in the 1960 brochure is a Seaway at 19'. This measures 4 more feet and an inch.
The beam width is also wider. The boat is pretty clean, the hull looks great but that open rib and no real deck bothers me although it appears to have lived that way all it's life. It feels surprisingly light. I could lift the stern on the boat lift with only moderate force. The hull isn't super deep, I don't see anyway it had a deck that was removed, the ribs end too far up the sides to have been hidden by a deck, it would have left it with very little remaining side depth. If anything was cut out or ground off, there would be some tell tale signs somewhere. Externally, it it looks just like my 1966 Niagara only much larger and stretched in length. The sides are no taller at the stern than that of the Niagara.
I'll hopefully have some pics this after this coming weekend.
The trailer is some sort of single rail single axle trailer with mono hub 8" rims. It looks like maybe an old Tee Nee or old Gator trailer. It's long enough but only supports the transom in the center, the two wood bunks are only about 20" long and mounted midway at the axle location. There are two front side bunks which contact the hull along the diagonal axle brace. The fenders are huge, and made of rounded aluminum, as is the main frame. The axle, springs, and coupler are the only steel parts on the frame. Event the keel rollers are wood.
There is no bow stop, only a forward roller that sits about 12" off the center rail in the middle.
reelfishin
Re: Unkown MFG?
I should have pics this weekend the boat is about 50 miles from here and I didn't have my truck when I saw it.
The best way to describe it is a Giant MFG Niagara, the dimensions and lines are the same only larger. It is longer in proportion than the other models.
The transom may have been done in Seacast, it's not wood, but it really don't look like it's been messed with other than the top edge is glass and not aluminum capped as on the other models.
The wide open hull is what really got me, no stringers, no wood, no floor. Just a huge open space. I don't even see anyway that they ever had seats mounted in this. Unless the just used portable seats. The hull is amazingly clean for being nearly 50 years old. No damage anywhere that I can see, not even a bump or bruise. Its still unpainted, all gelcoat.
I went to the MFG site and the closest thing I can find there is a 1960 Seaway but they're not 23' long. The Seaway is only a bit under 19'.
I even looked close to see if someone stretched it, and if they did, they did one hell of a job, as there's no sign of any glass work or changes in thickness along the sides. Its been in use recently, it's registration is only a few years out of date. The wide transom looks like it's made for twins, not sure how much it would take, but I'd venture it needs some real power to get on plane.
Or maybe its not meant to get on plane, being that big and all. To give an idea of the size of the boat, the guy that has it has a 14' V hull aluminum boat sitting inside the boat upside down on the floor and it fits with no problems with room to walk next to it on each side.
Mark42
Re: Unkown MFG?
I'll be interested in seeing those photos myself. Maybe you found a one-off model that never went into production? Would be cool, huh?
reelfishin
Re: Unkown MFG?
I'm not sure a one of boat would have been possible from MFG? Their boats were vacuum molded, meaning that they had to have build a form to make that hull.
My biggest concern is where to put it. I've been downsizing the fleet after I found a couple aluminum boats I liked better. I have everything to put the MFG together but I would no way have time this year to get to it. It would mean storing it for a year, and it would take up the space of two normal boats.
I have a good roller trailer for it, I have a motor, controls, steering, and just about everything else, except a bigger tow vehicle which for me is the deal breaker as far as building it. I sold off my 19' Renken because it was too heavy to launch with a small truck or car, this thing is a third larger.
It is light for it's size though, far lighter than any other larger boat I've seen.
My only concern would be how to mount seats in it since it has no fixed floor.
I've seen smaller MFG models with the decks out and have seen various cutaways, but this thing is nothing like those in design. The smaller boats have formed in stringers and minor ribs, this is all ribs, and the deck sits on the bottom of the boat. The design reminds me of a big aluminum boat with the deck removed. I would assume that the lapstrake sides do the job of the stringers and the ribs are only about 6" apart or so. It also has a very pronounced keel down the center, its about 4" high at about midship but flattens near the stern. The colors and shape of the hull are the same as Mark's Niagara above, only the windshield is only about 12" tall and metal framed all the way around. It's even in good shape yet.
The blue is faded but buffable. The best part is that the transom is rock solid and appears to be Seacast or something similar. Maybe original, I can't tell, I don't seen any place where it's been cut or modified and the original MFG foil decal/plate is still on the transom inner skin. It reads Model S9.
woosterken
Re: Unkown MFG?
I am with Mark on this one,looking through all the MFG brochures MFG only had one that big and it was a 24' cruiser in 1980
woosterken
reelfishin
Re: Unkown MFG?
It's definitely not a 1980, it's a lapstrake hull, with rope/cable steering. The steering wheel is also on the left.
This one looks like the 1960 Seaway pictured here:
http://www.fiberglassics.com/mfg/mfgb6004.jpg
Only about 4' longer in the stern. If I hadn't gone over it pretty well myself and have found no signs of repairs or mods being done, I'd have bet someone stretched a Seaway but when I check the rest of the specs, this one is also wider.
I was planning on getting down there to get it this week but it don't look like I'll get the chance till next weekend now. Getting that boat will mean having to let go of at least one or more of my other boats to make room for it. I think it would be great fishing platform but am leary about the amount of power it will take to move. I have a good V4 Evinrude but I think that it may need twins to move properly. I don't really want a boat that big, it would mean having to find a larger truck to haul and launch it. If it were aluminum, it would be a different story, but even then at 23', it would be heavy boat. My 18' Starchief is heavy enough. I've gotten really used to boats that I can launch and load alone with no effort.
I'm thinking that it would need about 200hp to really run right, or at the very minimum, a pair of 75hp 3 cylinders would be needed. It's a wide transom with all sorts of room. The problem would be finding a matched pair of motors for it. If not, one big V6. The problem then is fuel consumption. A boat that size will no doubt drink pretty heavy. On the plus side, I don't suppose it would draw much water, so it would be able to run just about anywhere around here.
I will go get it, but I may end up getting it just for all the super clean hardware that's on it. The bronze logos, step plates and other hardware is all mint and would look great on my Niagara.
