update 1889 searay 220
bolo789
ok guys i think i hit my recomend rpm by going down to a ss 15 pitch prop, well one more thing after i get on plane i try to raise the bow to get that nice bounce but the tab caunt raise the bow any higher. maybe tab too small or what???<br /><br /><br />i can get a lot more speed but if i try it kinda like the bow is plowing, any info
tommays
Re: update 1889 searay 220
are you useing a hydrofoil mounted on the drive or trim tabs on the hull ?<br /><br /><br />i use a foil and at speeds above about 30 MPH it has to much lift and starts to plow the bow<br /><br /><br />i usally run at about 25 to 26 mph and at those speeds its fine plenty of bow lift<br /><br />i have swim plaform on the transome that makes trim tab install bad or the foil would be long gone<br /><br />tommays
bolo789
hey tommy thanks, for the info.<br /><br />i has no foil only trim tabs i ges i have to cut back on the speed. <br /><br />what else can be done to get bow lift when tabs caunt do no more???
tommays
the tabs are going to push it DOWN they should be all the way up at speed <br /><br />at that point the only way to raise the bow is to trim the drive higher<br /><br />at some point you will start to get Prop Cavitation and then your to high<br /><br /><br />what speed and RPM are you geting now<br /><br />tommays
