We just removed the cylinder heads to take a peek and are dumb-founded!! The new one we put on still looks new. Although it says "Do Not Use Sealant", it looks like it didn't seal(melt into place?) and I know the motor over-heated. The old "Port" side gasket looks ok. When we squirted the hose up through the cyl. inputs, water did leak around both heads. Should we ignore the " Do Not Use Sealant" and put some good ole seal-a-gasket around them? Any opinions on a gasket sealant for one that's says "NO sealant" ? Thanks again, again
