Re: Update: horn works -restricted fuel vent seems to be the problem, 89 Evinrude 150
ezeke, thanks for the information. After reading your reply, i searched around to find out what QuickStart was and how it works. The problem we had in the drive way test was plugging in the wrong wires. The wires coming from the motor are discolored to the point you have to look really close to see which one is which. So, with the white and black wire from the switch incorrectly plugged into the tan wire going to the horn, as soon as the motor warmed up a little bit and was trying to tell QuickStart to dis-engage, that signal instead was sounding the horn. Getting the wires sorted out and plugged in where they belong solved that problem.
On to the lake test: Everything ran fine until WOT and shortly after that here comes the solid horn again. My buddy was trying to pump the fuel bulb to see if that helped and the bulb sucked completely flat and stayed that way. This is all new fuel stuff, completely back to the tank and the pick up tube is clear so we were pretty sure the problem was not in the fuel line. Unscrewed the fill cap to let it vent and made another couple of runs at WOT with no alarm. Pretty sure now that the vent is restricted some sort of way, kinked line or something. He had pulled the vent line off the tank earlier and was able to blow through it from both ends, so the only thing we can think of is it must be getting kinked somehow when it's installed on the tank. I can't think of anything else it could be but if anyone has any ideas, please let me know.
Also, we cant find any anti-siphon valve in this system. The pick up tube has a screen on the bottom, and the top of the tube goes into an aluminum block with a hose barb at the outlet for the fuel line to connect. There is nothing in that area - open passage all the way. Any other likely areas for an anti-siphon valve to be located?
Thanks to everyone who has helped so far in figuring out this problem.
