Update No power 1984 90hp merc
bigrich54
Since my last posting which had no replies? I changed the suspect fuel line, which did'nt help at all. Took the boat down to the water and it starts right up, idles fine, boggs down in gear, will not go over 2000rpm. Went home and pulled the plugs 1 at a time at idle and you could see a drop in rpm along with smokey exhaust for each plug removed. Pulled all plugs and ran WOT compression test 5 cyl. at 145 PSI and 1 at 135. Does'nt sound bad to me for a 1984.Anyone with a constuctive suggestion would be greatly apprecciated. Should I rebuild the carbs at this point? :confused:
The Marine Doctor
Re: Update No power 1984 90hp merc
Are you sure you have spark on all 6 cyl's at high speed...Maybe the high side of the stator is not working.<br /><br />TMD
bigrich54
How do you test for that? I can rev it up in Neutral, that's why I thought it was fuel.
