UPDATE of U-Joint that can be purchased at Auto zone
Status
Not open for further replies.
JohnKorte
I have a Alpha outdrive gen II, ser#OL417484. The part manual states that both were used for that serial #.
Grey Meritor 805536A2 or Black GKN 865493A01. Mine has been replaced by previous owner with a generic I think.
So I am trying to determine which one to buy.
thanks
Re: How to determine which u-joint to buy
thanks
Ayuh,.... Basically, yer choices are inner circlips, or outer circlips,...
Which do ya have,..??
'n up in the Adults Only section is a bunch of cross numbers for various manufacturers,...
JohnKorte
This is a non-greasable, sealed w/synthetic lithium grease u- joint from AutoZone. It fits the Alpha 1 gen II with inner clips.
1-6301DG, $15.99ea.
alldodge
Re: UPDATE of U-Joint that can be purchased at Auto zone
1-6301DG, $15.99ea.
OK and your question I think is this acceptable? If this is the question then I would say yes, it will work
Edit: BTW http://www.summitracing.com/parts/axe-1-0134 this is one with fitting
JohnKorte
As stated this post was just an update of U-joints. The info in the "adults only" section as well as everything found in this forum is invaluable to us all. I thank all responsible for this free service. I could not service my boat with out it. The reason for the "update". A few of the cross reference part numbers cannot be found at the auto part stores in my area. Also the u-joints are of the grease able kind. The part offered at AZ seems like a excellent part replacement with a excellent price. Maybe if the powers at hand see it fit they might add it to the rest of interchangeable part numbers. I thank everyone for your help.
The rest of my parts will be in soon and Iam sure I will have more questions to get my boat on the water again.
Duralast Gold/U-Joint (1-6301DG) | AutoZone.com
Status
