rcdatadude
- Nov 29, 2009
- 26
I'm troubleshooting the precision blend system on my 1990 Yamaha ProV 150. I've checked all the continuity based on posts I've found on this forum, and the results fall in line with what others have posted. The last thing I tried was to turn the key on to apply 12V to the brown wire going to the remote tank. Then I grounded the blue wire. It didn't appear that anything was happening. Should I be able to hear the oil pump running? The emergency switch doesn't appear to start the pump either. I guess, based on that, the oil pump needs to be replaced. Is there a fuse in the link anywhere between the oil pump and the first disconnect in the harness? Any help would be greatly appreciated. Thanks!
