Update on possible trigger problem.
les morgan
Post from laddies on my original thread said that loss of fire on two cylinders
(1985 merc 50hp 4cyl) was possibly not the stator- should affect all cylinders.
Ordered new trigger and the instructions with the trigger states the following.
----No fire on two cylinders--------
Swap the red with the red/white and the blue with the blue/white stator wires.
If the problem moves, replace the stator.......If the problem stays on the same cylinders, swap the trigger wires from top to bottom, #1 for #3 and #2 for #4. If the problem stays on the same cylinders, replace the pack.
Now my question is, will the trigger cause the loss of fire on the top two cylinders?
Thanks
Les Morgan
Laddies
Banned
Re: Update on possible trigger problem.
Yes, as the instructions say a bad trigger will effect 1 & 2 or 3 & 4 cyls. A stator is checked by swapping the red to red/white and the blue to the blue/white if the problem move it's a bad stator.
