Updating cooling system
RCAnderson
I have a mercruiser 888 with full closed cooling. I would like to add an inboard mounted raw water pump similar to this :
Jabsco Cooling Pumps 43210-0001 - iboats
Can someone tell me approx. how big in diameter the pulley mounted to this has to be to get the correct rpm on the pump ? Not too big and running too slowly, and not to small and running too fast. I suppose faster would be better than slower though. I have an accessory pulley directly on the front of the crankshaft that is 6 inches in diameter.
I am also wondering if I can remove the impellor from the outdrive and leave the housing, and use the raw water intake through the outdrive to provide water to the inlet of the inboard mounted pump.
Will I need a check valve before the pump to prevent raw water draining back when the engine is stopped, then having the pump start dry ?
My reasoning behind all this is that I was on another boat a couple of weeks ago which was equipped with an inboard mounted water pump, and about 40 miles beyond nowhere, the engine overheated and derated itself. Sure enough, it was a blown impellor, which we were able to change while we bobbed around on the ocean. I was thinking later on, and if you lose an impellor in a lower outdrive, there is no way you will be able to change it on the water, even if you do pack a spare. There are not very many beaches in my part of the world, just rocky flat spots, so beaching with the kicker and waiting for a lower tide would not be a very good option.
Anyway, if anyone has any thoughts on this, they would be appreciated.
Ryan
thumpar
Re: Updating cooling system
If you change the impellor on a schedule you won't have a problem. I change mine every 2 years but we only get about 15 hours run time a year. Also don't ever run without water.
RCAnderson
I do change my impellor every year, and I might put in something in the neighborhood of 200-300 hrs per year. However, the impellor in the other boat gets changed on a schedule as well, and it was only changed about 150 hrs ago, when the rest of the service was done on the engine and outdrive @ 1200 hrs. (This is a workboat, on it's third engine over the hull life, and gets regular service) So it just goes to show, that the impellors do blow from time to time, scheduled change or not, and I am thinking about not getting stranded or having to try to run back home on my kicker. I also try to keep my boat in the water when it's running.
RCAnderson
Anyone with any input on removing the impellor from the outdrive and using the water intake ? Or would this be too restrictive ?
Grub54891
Should be fine,the bravos pick up through the drive.
Grub
