My trailer is for a 14' McKee Craft and most of it is working properly. However, its starting to make me very nervous. The wheels and bearings are fine, but almost everything that hold the boat on the trailer is in need of a replacement.
For starters the bunks are only attached in the back, simple fix, but the question is: Should I just replace them, or just screw them back down? Got trailer used, and have no idea how old they are, they seem okay and are carpeted wood.
My biggest concern is the winch assembly and stand. The winch is actually a thick metal wire, parts of it seem a little rusty. The stand itself is what freaks me out the most. It is a stand with two arms coming out and grabbing the front of the boat. The following link shows how the front of the winch stand looks. The problem is that the front of the boat does not line up into the bow guards.
http://www.custompontoonboatkitsetc.com/id18.html
I want to replace it with a new winch stand and winch. The winch I would like to be used with a strap perhaps? The stand I want just the center stand with the single bow "roller" type of front. Can anyone suggest some good brands, or perhaps a better set up?
Last but not least, I wanted to ask about transom savers. My boat is old, and the top of the transom was just redone. Got a 25 HP new yami on it (186 lbs). Does NOT have power trim and tilt and when I drive around on the crappy Miami roads, it bounces a little. Are these transom savers worth the money? I am new to trailering and it still creeps me out a little, so I want everything to be safe, and last.
Thanks so much.
Thanks so much.
