Fishermark
- Oct 19, 2003
- 5,617
I currently have the old Mercruiser trim system on the boat I am working on - 1972 Sea Ray. It has the separate reverse lock out mechanism. (It's pictured below). The outdrive is a model 1. (I believe - I know it predates the Alpha, and has the eye hook in the top).
If I decide to replace the trim pump, does anyone know if it is possible to replace the pump with a later model one that has the reverse lock out built in? (The I can do away with the separate pieces)
If so, can I keep my old, small diameter rams? Or do I need to replace them as well?
