Dr Tim is very correct. He has found the force. Keep testing your 25. Are the butterfly's opening all the way?If the motor is running well and reaching max rpm you may not get much more out of it. What is your guess on the weight you pushing?
2 people and a load of gear can mean many things.
If your reaching max rpm have your tilt set correctly and weight distribution is good I don’t know that you will gain much more than what you have out of a 25hp. 22mph isn’t to bad.
Jmo
While it will bolt on, things like the Cam on the Armature Plate is often different, and often the Intake Manifold is different. At best, if you are able to gain any power, it is only gonna be a mile or 2 mph more.Find a used 30 or 35 HP carb in compatible years...direct swap.
Get a tach, make sure your in the rpm curve by selecting the right prop.
Go on a diet.
This day just gets better and better!
Very cool on the "RedTail" name....those boys were awesome fliers !Comedy Central is now here...and I got a good laugh.
Jimbo was the best but Racerone was a close second.
Sometimes just working on them or painting them different is fun...
And I enjoy it.
My 1974 Lund does 27 with a fully loaded boat. Motor is a 1985 fully stock 30 HP johnson...or is it. I'm running an 11 inch pitch stock prop and it's right down the middle in the rpm range. I really don't care, I just have fun seeing what else i can do to it.
Thank you.![]()
Comedy? I was being dead Serious about leaving the Wife, Kids....Comedy Central is now here...and I got a good laugh.
A buddy at work always said separating from his wife was simply to much pain to bear .He could not bear the pain of serarating himself from half of his estate !Comedy? I was being dead Serious about leaving the Wife, Kids....
