Looks like it's going to be a tricky re install...
Ayuh,..... How so,..??
If the fuel pump push-rod gets in the way, there's a real short bolt on the front of the block, in-line with the push-rod,....
Remove it, 'n install a longer bolt, push the push-rod Up, hold it there, then screw in the longer bolt til it just touches the push-rod, holdin' it in the Up position,....
Ya might need to bump the motor over abit to bring the flat of the cam 'round to the right point,...
Install the fuel pump, then remove the longer bolt, 'n put the real short bolt back into the hole,....
It oughta be ready to fire it up at that point,....
