Upholstery help
iaff284
I've been lurking here for awhile trying to soak up as much knowledge as possible for my upcoming interior work. I have seen lots of examples of seats with piping but few without. Below are some pics of the sunpad and rear seat back for my 1994 225BR Crownline that I need to redo. I have a Singer sewing machine model 5525 from the 70's that I am hoping will handle the work. This is my first attempt at sewing but I am mechanically inclined and dont anticipate alot of probpems. How difficult will it be to cut and resew the entire sunpad and the white portion of the rear seating?
Woodonglass
Re: Upholstery help
Welcome to iBoats!
Pics did not attach. How HARD will it be? That's HARD to define. It all depends on your aptitude. Some people take to sewing like a duck to water. Others....not so much. Not familiar with that Machine. Piping requires a machine to be able to sew through 4-6 layers of vinyl. Thats tough for a non commercial machine. Not saying it can't be done just tough to do. Making an sewing piping is fairly easy. Semi flat felled seams and Full Flat felled seams are fairly simple as well. Again the machine can really make all the difference. Here's a video that will really help you.
http://www.youtube.com/watch?v=2BvIr1mNYiE
JDA1975
Re: Upholstery help
The easiest way to recreate something specific is to take the time to tear out the old seams and use those pieces as templates for your new cuts...sewing them together just takes patience and a steady hand....keep the machine speed low until you get the feel for it, do not push or pull the material, the machine will do that work, just guide it. your sun pad will probably be the most difficult because of the long sweeping curves....if you get off track on those it can create a problem with the way they lay from that point on...also vinyl tends to stretch if you do not have a walking foot machine, the top will not feed as evenly as the bottom and when you get to the end it is 1-2" longer that when you started....on a straight stitch it can be fixed by squaring it all up and cutting off excess but on curves like that stretching one more than the other can affect its lie as well...
I would get some vinyl and do some practice with curves and stitches prior to cutting it all up, should you find that it is not for you, your local upholstery shop will like it better if your covers are still in once piece if you plan to do a copy of original designs!
iaff284
Re: Upholstery help
Thanks for the info JDA....I had planned on getting a walking foot as they are available for my machine. Practicing on other pieces is a good idea, are the seams for the seats just two pieces sewn together? Also I was planning on using painted 3/4" mdo for the supporting wood on the seats and sunpad. Do you have any experience with that or do you recommend something else? Thanks for the help
JDA1975
Re: Upholstery help
home machine "walking" foot is not quite the same, its more of an even feed foot, but it will be a better choice of presser foot for most of your sewing...the seats look like separate panels with a tufting piece sewn on to get the pucker effect...when it comes time to wrap it you will wrap the small cushion by stapling it down then add the large cushion which will give it that effect...when you get to taking it apart you will get an idea of it
