TwoBallScrewBall
- Sep 14, 2003
- 1,695
Hi,<br /><br />Well now that I'm sure my boat is seaworthy, it's time to make it look a little better. 1988 Bayliner Capri.<br /><br />The vinyl, especially in the bow area, is shot. Looks like mice or something nested in it. Maybe a cat used it as a scratching post. Anyway, I am going to refoam and revinyl the pads that run along the sides of the seating area. SInce they are shot already I had no problem slicing them open to take a look. The assembly is confusing me. The pads are 1/2" ply with foam glued to them, then vinyl stapled from the back. The thing that puzzles me is the way they're attached to the fiberglass... The screws go in from the front side, under the foam and vinyl. As far as I can tell, to build them this way means that you have to cut the wood, then staple the vinyl over the top edges, then screw the wood to the boat, then glue on the foam and wrap around the vinyl, then reach up around the back and staple the bottom of the vinyl. Does this sound right? <br /><br />Anyone ever reupholstered a capri want to lend some advice? I'm thinking of drilling holes through the ply and the fiberglass, installing blind nuts on the front side of the ply, then completely upholstering the panels and screwinf them in from the back, but space is tight. <br /><br />Thanks!
