Model: DPS-B 1.95
I am having an issue where when shifting into forward or reverse the boat shifts very hard. I talked with Volvo and they brought up checking the upper gear shaft washer to nut clearance (pictured). I was informed that I should have between .004" to .020" clearance between washer and nut (I marked the area measured). I was unable to get a .0015" shim in between these surfaces (the washer does spin). Am I measuring the correct spot?
Should I install a thinner washer?
The current washer number is 6, does anyone have the washer part numbers for the thinner ones?
Thanks in advance,
Krummel21
Thanks in advance,
Krummel21
