upper housing?
sampler
looking to buy a used upper housing that is from the 1967-1969 120/140 model with the housing #is 2652898 and i have a 1968 160 model #is 2065985. does any one know if they are the same housing?????????? any help would be greatful.
Re: upper housing?
Ayuh,... The Housing is the same, the Gears are different...
sampler
Re: upper housing?
i have the old gears out of the 160 but the housing drop and broke off at the wear the u-joints and the yoke go in to. the housing iam looking at is just the housing and no gears in it.
Re: upper housing?
Ayuh,... There are manuals up in the Adults Only section of this forum,...
Grab a copy of the 1 for your drive,... It's a pretty Involved process that you're headed into...
Good Luck...
