Upper/Lower Mounts, Swivel Shaft
olbone
I have a 2000 Merc 125 with about 500 hrs. The upper mounts, lower mounts, and swivel shaft are worn out (loose) and while running, the motor looks like it is about to come off the boat. The authorized Merc mechanic and the factory representative both acknowledge that the "failure is premature" and that they have seen it happen before. However, Merc will do nothing about it......"it is out of warranty". Total bill over $1,000. Ouch.<br /><br />Been waiting for a month for the swivel shaft. Talked to Merc and they have no idea when they will get one.<br /><br />Has anyone out there had or heard of this problem?<br /><br />Does anyone know how I can get the part?<br /><br />Thanks for comments.<br /><br />Mark
rodbolt
Re: Upper/Lower Mounts, Swivel Shaft
hello<br /> all the time. the mid 90's classic fifty and inline 4 forty HP ate mounts. usually busted up the lower bracket as well. sorry merc wont help. I did find that usually the upper mounts were roasted by a blown adaptor gasket just prior to failing<br /> good luck and keep posting
