nola mike
- Apr 22, 2009
- 5,695
pulled the outdrive today, noticed some water in the shift shaft cavity. also noticed the upper seal free floating on the shaft. i think i have the correct part to replace with the new style bushing. i've been looking for a how-to, but haven't seen one.
1. how do i remove the shift shaft? looks like a set screw holds the shift arm on. if that's the case, it's going to strip out and i'll need to drill it i guess
2. do i need to remove the bellhousing?
3. how do i get the old bushing out/new bushing in (esp if the bellhousing remains on?)
alpha one, gen 1 btw
