Upper unit installation
chimo1
On a Stern drive unit 1980 when you re-install the upper unit the manual says once engine has been replace you must use an alignment tool before you reinstall the upper housing. If you only removed the stern drive is it still required to use the alignment tool before installing the stern drive back into the bell housing ?
Haut Medoc
Re: Upper unit installation
Required? No, but it is good to check it once a year......JK
