URGENT need a couple of answers merc 50 with pic
NiSsMo
i stripped my carbs down and found a jet that goes all the way through the carb to have a crack all the way down it, this jet goes to the mixture screw and to the front of the throttle plate. (the hole just after the plate downstream) <br />Q) would this affect the idle? i got this problem.<br /><br />QUOTE from my recent post <br /><br /> " my merc 50 blueband wont idle it only starts with the choke on (hot or cold) and thats with the warm up leaver up. when its running if you put the leaver down it will die, if you try to put it up before it dies it wont pick up just will just stop, the boat goes well up top end it will pull the side off a tug boat, and spends most of its time out of the water, just this stupid problem, im sure its not a fuel blockage coz it goes good up top, do they have idle jets? i have stored it a few times without running it out of fuel, but the problem has been there since i got it. i do run it out of fuel now, the plugs are good and i use new fuel all the time"<br /><br />is it an idle jet?, would this stop the wole motor idling? , i figure that the vacuum will not suck fuel up this jet at idle and the crack would let air in and the cyl would not fire. if this is correct shouldnt it just run on two cyls? or is it enough power drop to stop it going? <br />thanks for the helpful information.
attachment.php
NiSsMo
Re: URGENT need a couple of answers merc 50 with pic
that is the jet the black line is the crack.
